Why is the head gasket blocking the lifters?
Old 04-17-2009, 07:36 PM
red-_-z28's Avatar
Default Why is the head gasket blocking the lifters?
I just removed the rockers and pushrods and i thought i could just use a magnet to remove the lifters but there's a gasket material blocking the removal.
Old 04-17-2009, 07:40 PM
the_merv's Avatar
If you haven't pulled the Intake you have alot more than just the Gasket blocking them..lol
You have to pull the Intake and then remove the Spider Plate and Lifter Retainers to get to the Lifters.
Old 04-17-2009, 07:55 PM
Badazz 97 TA's Avatar
haha, yeah man, the intake manifold needs to come off to remove the lifters. no other way around it.
heres what your engine will look like when the manifold is removed
Old 04-17-2009, 08:28 PM
red-_-z28's Avatar
lol ohh okay nevermind on that
Old 04-18-2009, 05:32 PM
red-_-z28's Avatar
Okay so it seems im removing the intake
Old 04-18-2009, 05:36 PM
Formula350's Avatar
Be sure to be liberal with the RTV on the front and back edges, but not TOO liberal! Otherwise drips of RTV could fall down, get pulverized and sucked into the oil galleries I suggest using some quality RTV as well, not the stuff that comes with the gaskets. Get some of "The Right Stuff".
I guess Ace Hardware sells it too.
Old 04-18-2009, 05:40 PM
red-_-z28's Avatar
okay thank you!
what is the spider plate?
Old 04-18-2009, 05:46 PM
strokin93z's Avatar
its the plate that is holding each dog bone down over the lifter. has three bolts on top of it. Kinda looks like a spider.
Old 04-18-2009, 05:54 PM
the_merv's Avatar
You'll know it when you see it..
Old 04-18-2009, 06:07 PM
Formula350's Avatar
And what is a Dog Bone? It's what the lifters slide through lol
Spider plate is in the middle (light colored steel)
Dog Bone:
Some dog bones also surround the whole lifter body, but I don't see either one being better than the other.
Here's a better pic:
And a suuuper sized version of it:
http://msdproductnews.com/_uploads/p...es/08-1001.jpg
Old 04-18-2009, 07:38 PM
strokin93z's Avatar
^ very good pictures Forumla! thanks.
Old 04-18-2009, 07:56 PM
Formula350's Avatar
No prob. I'm a Jedi Master of lol
Old 04-18-2009, 08:15 PM
the_merv's Avatar
Nice pics.. I was going to post pics of my build, but I wasn't on my Computer.
Good looking out.
Old 04-18-2009, 10:03 PM
red-_-z28's Avatar
dang guys! thanks alot!! so i got the so called Spider off and i had problems with one of the lifters, it wouldnt push in, as if it was jammed! so thats good! do you think that would call a random knocking/clanking sound?
Old 04-19-2009, 08:13 AM
the_merv's Avatar
What do you mean it was jammed..as in the Cup wouldn't move down in the Lifter?
Old 04-19-2009, 06:45 PM
red-_-z28's Avatar
yes like it wouldn't compress
Old 04-19-2009, 07:40 PM
7.0 camaro's Avatar
so why is the gasket made like that. i tried to look in mine for some issues and cant see nothing from the gaskets. it dont need to be there. i know that. so what is there reason for doing it.
Old 04-20-2009, 10:01 AM
Formula350's Avatar
Someone posted before reading the whole thread...
Red: They shouldn't compress easily by hand since they'll have oil in them, which is why they're called Hydraulic lifters (hydraulic roller in this case). Some may be able to get pushed down a bit since some oil could've drained out, but when you get the motor running again they should 'pump up' (fill with oil) again and all is well. As for the sound, um... I guess it could, but there's lots of other things that can cause knocking/clanking noises :\
Quick Reply: Why is the head gasket blocking the lifters?
