The Firechicken Project
Old 04-21-2009, 01:08 AM
93 black t/a's Avatar
Default The Firechicken Project
Well the build is almost finished.
355
stock crank
studded mains
forged eagle 6 inch rods
forged flat top weisco pistons
11.7 to 1 compression
head studs
LE2 h/c/i (23x/24x, 53x/54x, 110 lsa)
1.6 pro mag rockers
36lb svo injectors
58mm bbk tb
all accessories deleted
electric water pump
pacesetters lt's
little red button
spec 3 clutch
ford 9 inch with spool
spohn torque arm, cross member with ds loop, adjustable lca, 1 inch sway bar, adjustable panhard bar.
I owe a huge thanks to Robert and Debbie at MIDWEST TRANSMISSION for all of there help on this project, couldn't have done it with out them. The goal is to have it dropped in this weekend. Heres a few pics
http://www.facebook.com/album.php?ai...9&l=d428bfd794
Old 04-21-2009, 08:40 AM
SoxXpupPeT's Avatar
looks great so far! that things going to be a monster when its put back together. what kinda power numbers do you think shell put down ? GL on the install
Old 04-21-2009, 08:42 AM
Elliott's94Z's Avatar
Yeah looking great man!
Old 04-21-2009, 09:31 AM
trippinholyman's Avatar
beautiful, now when you're done save up some money, get some custom made emblems of a rooster on fire and paint / put a decal of a rooster on fire on your hood, then its totally complete!
Old 04-21-2009, 11:00 AM
one step ahead of you its not a flaming rooster but i like it. i need to get it re done again and bright the color up a little
http://www.facebook.com/photo.php?pi...&id=1309620089
Old 04-21-2009, 11:44 AM
good enough! thought the flamin rooster would be funnier
Old 04-21-2009, 12:09 PM
ss.slp.ls1's Avatar
I hate you!!!
Old 04-21-2009, 12:56 PM
AChotrod's Avatar
Its gonna be a beast!!!!! Sweet build!!!!
Old 04-21-2009, 03:29 PM
za355tx's Avatar
Sounds pretty similer to my setup. It should definitely be a strong runner. Makes me wonder about your cam...mine is also a 23x/24x.
Old 04-21-2009, 04:41 PM
LS1 SPEED's Avatar
nice build man
I look forward to seeing your results.
Old 04-21-2009, 04:44 PM
92camaroguy's Avatar
Originally Posted by ss.slp.ls1
I hate you!!!
X2
Jk Nice car and nicer build!!
Old 04-21-2009, 08:35 PM
Thanks guys. I'm really ready to get this thing done. I also forgot to add a huge thanks to lloyd for all his help and patience with all my questions.
Old 04-21-2009, 08:54 PM
brokenbird's Avatar
man its going good i cant wait to see you out in it enjoying it like its ment to be cause i want a race as soon as i get my rearend built
Old 05-05-2009, 01:47 AM
Well the motor is in the car now, with everything plugged in and what not but it wont start. You can here the soleniod clicking and the starter trying to move, but it won't turn over. Also tried jump starting it with no luck. Any ideas??
Updated pics
Old 05-05-2009, 09:26 AM
MTBSully's Avatar
Updated pics
may need to shim the starter? Also make sure you dont have a leaky injector which could mean it is hydrolocked
Old 05-06-2009, 12:31 AM
skinnies's Avatar
Looks good, should run very strong, I ran pretty much the same setup but with a th400.
He posted on the local forum it turns over by hand freely.
Old 05-06-2009, 12:36 AM
Yup, i got it figured out, and it was a ground wire. It finally fired tonight!! I was so glad to hear it finally run again. I think if i adjust the TB screw it might even wanna idle. I'm calling redline performance tomorrow in STL, to see if they can get me next week sometime to get it tuned. I hope to get the suspension setup tomorrow well enough so i can drive it a little to break it in.
Old 05-06-2009, 01:24 AM
za355tx's Avatar
Yeah you can try adjusting the screw but like me you'll need to adjust the TPS and IAC. I already adjusted the screw to help it idle but need to reset the TPS and check the IAC. I'm sure you're loving the way it sounds. I know I'm liking the way mine sounds. Sounds like a full blown race car.
Are you running it with the bigger injectors untuned? It would be a shame to have it done and then flow the cylinders with fuel.
Old 06-04-2009, 11:19 AM
Well i think its finally time for a update I had the car, street tuned finally. I think with a dyno tune i might be able to get a little more out of it. It put down 377hp/342tq. I'll try and get the graph up soon. I took it to the track last night, and ran 2 11.89 passes, one at 115.78 and the other at 116.02. The car has a miss to it. I think its a plug wire, because they're brand new plugs, I put them in yesterday hoping that would fix it. I'm gonna try and trouble shoot it some today and figure it out.
Old 06-06-2009, 05:25 AM
skinnies's Avatar
What was the DA when you ran? Not bad for your first night out at the track with it.
Quick Reply: The Firechicken Project
