Can fuel pressure affect idle?
at cold start idle is sometimes normal but sometimes bout a thousand..when its warmed up on the second start up its bout normal..now i know that i have long cranking to start..cuz my fuel pump is going south...just wanted to know can fuel pressure affect idle??thanks
well i cycle the key to get it started faster.and it does stumble at cold start with the first drive but after its been warm and on the second start up its fine like the pressure is changed after it warms up..only problem for me right now in changing it is...i got a free fuel pump but! but my sending unit is all wacked out and if im going to change the fuel pump then i should change the sending unit with all that work you know.yea and a dealer part is a ton!
