milled heads.... gaskets thickness....
Old 05-02-2009, 12:22 AM
FbodyFreak's Avatar
Default milled heads.... gaskets thickness....
Ok guys so heres the thing..... I got a set of stock ported T.E.A heads that have been milled 25 thousandths to make the combustion chambers 52cc. Now, the question is if the gaskets I got will work.... they are 4.125 bore, .050 compressed thickness.... and will the valves hit my pistons is a bigger question....
PLEASE....
PLEASE HELP!!!!
Old 05-02-2009, 12:28 AM
BOLO's Avatar
You should have plenty of valve to piston clearance if you're just running the LT4 hotcam from what I see on your sig.
Old 05-02-2009, 12:34 AM
James Montigny's Avatar
LT1s do not generally have PTV issues, especially not with a stock deck height.
FWIW, I run a zero deck, .028" gaskets, .610" lift cam and my heads were milled from 58cc
down to 56cc and PTV was not even close to being an issue.
Old 05-02-2009, 01:03 AM
FbodyFreak's Avatar
Its funny u say that because today I just ordered the AI 230/238 .575/.575 110lsa cam. So let's hope ha ha..... and will those gaskets I already have work(.050 compressed thickness) or do I need different ones?
Old 05-02-2009, 01:05 AM
.050 will work, but you can certainly go thinner if you want to increase CR a little.
Old 05-02-2009, 01:06 AM
FbodyFreak's Avatar
...and if I happen to need different gaskets, which do you guys preffer(sorry with the noob sounding questions)....
Old 05-02-2009, 01:10 AM
.028" GM "Impala" gaskets are what I use. PN 12553160
Felpro makes a .039"
Mr Gasket makes a .026" . I've used those before without issue.
Old 05-02-2009, 01:18 AM
FbodyFreak's Avatar
Ok!!! Thanks man!!! You have been a VERY BIG HELP!!!!
Old 05-02-2009, 07:53 AM
tonskiguy's Avatar
If your block has not been decked, your pistons are probably "in the hole" about .010" - .015". Optimal quench height is .039", so the .026", .028", or .039" will be better than the .050". Make sure to use good head bolts.
Old 05-02-2009, 10:19 AM
FbodyFreak's Avatar
Ok soo.... I think I will probably be getting the .028 gaskets..... and the head bolts I got ar ARP hex head bolts
Old 05-02-2009, 10:24 AM
za355tx's Avatar
Lloyd says optimal quench is .031 not .039. And I'm pretty sure that a stock motor will have the pistons deeper in the hole than that.
With a cam that size you need some compression. Go for either the Mr. Gasket 5716 or the GM impala gasket.
Old 05-02-2009, 10:27 AM
RamAir95TA's Avatar
Agreed. My stock pistons were in the hole .025". Once the block was decked, I have quench around .030".
Old 05-02-2009, 10:30 AM
"Optimal" depends on the application.
How close are you willing to let those pistons come to kissing the heads?
Generally, you want to have at least .030"-.035" between piston and head to
accomodate piston rock and rod stretching in extreme weather.
In a dedicated drag car, people are willing to push that a little tighter.
Old 05-02-2009, 10:39 AM
96capricemgr's Avatar
The stock shortblocks I have measured were .022-.032. down.
Quick Reply: milled heads.... gaskets thickness....
