Needs some help with lifters.
Old 05-02-2009, 07:57 PM
DarkKnightRider's Avatar
Default Needs some help with lifters.
Ok so I'm putting in a new cam I have new pushrods and new springs. I just realized that I spaces on getting new lifters. I have been told that ls7 lifters would work on my block. That they are the same dimensions as my stock lt1 lifters. Is that true. If not what should I get
Old 05-02-2009, 07:59 PM
Elliott's94Z's Avatar
They are basically OEM replacements now. I'm running them on the 383 build I'm doing. Ran them on the LE2 set up as well. Best bang for the buck. So yes, they will work.
Old 05-02-2009, 08:14 PM
Sweet that's what I was hoping for.
Old 05-02-2009, 08:23 PM
Tons of guys are running them on here. Nice lifters for the $$. GMPARTSDIRECT had the best price around when I was in the market for them.
Old 05-02-2009, 10:44 PM
Are the ls7 lifters any different than stockers?
Old 05-03-2009, 11:49 AM
Someone correct me if I'm wrong, but I believe they withstand higher RPM's??? I think that's the rumor anyhow..I don't remember off hand.
Old 05-03-2009, 01:02 PM
95maroz28's Avatar
gonna pick up some ls7 lifters myself. from what ive seen the ls7 lifters say they handle 7k rpm or so and the caddy racing lifters up to 8k?
Old 05-03-2009, 02:45 PM
my big worry is figment with the new cam the lifters springs and everything.I just want it all to work right.
Old 05-03-2009, 03:19 PM
It will be just fine..
Old 05-03-2009, 11:19 PM
airfix's Avatar
Yup you are correct.
Old 05-04-2009, 06:45 AM
leadfoot4's Avatar
Not to rain on anybody's parade, but... Wasn't there some discussion a while back, saying that the pushrod seat in the LS7 lifter was a tad lower in the body than the LT1, LS1 lifter, therefore even though the outer dimensions were the same, the LS7 lifter could require a longer pushrod to maintain proper geometry?
Old 05-04-2009, 08:33 AM
94Z28rag's Avatar
That is correct. Measure to be sure.
Old 05-04-2009, 01:56 PM
RamAir95TA's Avatar
Definitely a valid statement. Some have said that the cup is up to .100" deeper into the lifter body. Just to be safe, I would measure.
Old 05-04-2009, 01:59 PM
StealthFormula's Avatar
It's best is to measure just in case. In my case the pushrod cup was not any different than my original lifters.
Old 05-04-2009, 02:22 PM
ss.slp.ls1's Avatar
+1 on the LS7 lifters working without a problem. As a matter of fact, if you want to get new hydraulic roller lifters for any SBC (including LT1's) from the dealer, they will give you LS7 lifters.
+1 on measuring for peace of mind.
When will you be finished? Did you go with the CC503 like I told you to?
