gas leak ? oil leak ?
Old 05-04-2009, 11:48 PM
killagt's Avatar
Default gas leak ? oil leak ?
I just look at my top of the intake manifold, I saw a brown wet spot, it on the tube that connect both fuel rail together, next to the TB. here the pix ( if not my engine bay, I dont have camera with me right now, so i google it ). what its and how to fix it ? does it have o-ring or something ? thanks
Old 05-05-2009, 07:06 AM
DAVE00's Avatar
Yes there is an o-ring in there for the crossover tube, see the diagram below (courtesy of Shbox):
FYI - This is if you have the 94-97 fuel rail
Old 05-05-2009, 10:02 AM
killagt's Avatar
for being a noob, where I can get this O-ring and how to change it out ? thanks
Old 05-05-2009, 12:25 PM
ss.slp.ls1's Avatar
Pull the rail, unscrew the cross over tube from both sides of the rail. remove the o-rings on both sides and get new ones the same size that will fit snug on the tube. screw it back together making sure that the crossover tube and flanges seat flush with each side of the rail. Bolt it back down and keep an eye on it to see if it stops leaking.
Old 05-05-2009, 07:27 PM
killagt's Avatar
I call up my part store and they do not carry any o-ring for that fuel rail, does any one know where I can order online, and btw what else I should replace while im taking the rail off. thanks
Old 05-05-2009, 07:28 PM
ss.slp.ls1's Avatar
Just get a o-ring from any parts store that is the same size and fits snug on the pipe.
Old 05-06-2009, 06:38 AM
DAVE00's Avatar
+1 - you can get a pack of em' in various sizes at your AP. Just test and find the one that matches up best.
Old 05-07-2009, 01:01 AM
killagt's Avatar
[/QUOTE]
I just take off the fuel rail, that #2 oring is tear up pretty bad, every other oring look really good. I find out that one of the fuel injector retainer is missing, can I buy this off part store without going to dealer ?
thanks
Old 05-07-2009, 06:35 AM
DAVE00's Avatar
The injector clips have one side open and are shaped like a C in the middle. Slide the clip laterally along the rail away from the injector (might be a little tough being on there so long) and once clear the injector is just held in by the upper o-ring and it will pull out (might take a little tugging). Really easy to do and you'll have all the injectors out within mins - you'll see what I'm talking about. FYI - You can buy injector o-ring kits from your local AP or online for wayyyyy cheaper then the dealer so don't think you're stuck with them.
PS: Look in the diagram above and you'll see #19 is one of the injector clips, see how it is shaped like a C and will only slide off one way. The little tabs at the top of the pic hold the clip to the rail and they will keep it there, you don't want to bend these just slide along the rail away from the injector you are removing.
Old 05-07-2009, 10:09 AM
killagt's Avatar
thanks
Old 05-07-2009, 10:41 AM
Ralls's Avatar
I bought that o-ring kit recently. It's part #17113086. Cost me $6 + shipping from GM parts Direct.
I have my old o-rings still if you want them. I was comparing them with the new one's and they still seemed new.
Old 05-07-2009, 10:42 AM
RamAir95TA's Avatar
I'm calling copyright infringement.
Old 05-07-2009, 04:48 PM
killagt's Avatar
is that the kit that came with 0-ring #2 for cross over tube ? and should I replace all the oring on the injector ? or just the cross over fuel rail rings ?
Old 05-07-2009, 04:53 PM
ss.slp.ls1's Avatar
O-rings aren't expensive, might as well replace them all.
Old 05-07-2009, 05:16 PM
Ralls's Avatar
Yeh it comes with both #2's, #15, and #12.
It doesn't come with injector o-rings. That would be separate. Honestly you shouldn't have to replace them unless they are dry-rotting or cut. But it wouldn't hurt if you had the extra cash.
And I wouldn't use just any o-ring. Those are stiff and I would imagine designed for fuel.
Old 05-07-2009, 06:56 PM
killagt's Avatar
Can you or any one can give me the part number for top and bottem fuel injector oring please.
Old 05-07-2009, 07:02 PM
ss.slp.ls1's Avatar
17113544
don't know if that includes both top and bottom, but I think it does.
Old 05-08-2009, 10:48 PM
killagt's Avatar
Originally Posted by ss.slp.ls1
17113544
R u sure ? or can any one comfirm this before I place my order ? thanks
Old 05-12-2009, 09:24 PM
killagt's Avatar
what else I need to replace while im removing fuel rail and injector ? beside all the O-ring ? thanks
Old 05-13-2009, 11:25 AM
ss.slp.ls1's Avatar
You could always throw on a new fuel pressure regulator, but that's just being extra cautious.
Other than that, you've got it all covered.
Quick Reply: gas leak ? oil leak ?
