Starting trouble!
Starting trouble!
Okay, so when I first got the car a few months ago I got it home and a few days later I got in and it would turn over fine, but nothing happened. After several minutes of turning it over it started to hit a little, then more and more, til finally it started. After that it run good for a couple days, til it did it again. I thought it was flooding due to leaking injectors, so I bought new ones. Man the car got a renewed life had lots more power and started fine, for a while. Today a couple weeks later it is doing it again.
It will turn over easily, iff you hold it down for thirty seconds or so, when you let off it will act like it is trying to start, but the crank is going the wrong way. Then you try again and it turns right til you let off then backwards again. It started to hit alittle, but my battery went dead.
So any input would be greatly appresiated.
Thanks guys.
Thanks guys.
Thanks guys.
Thanks guys.
But you are saying that when you stop cranking it, it will actually start to spin counter clock wise when looking at the engine form the front?
Okay, while trying to start the car last night I run the battery down. I charged it all day. When I got in it today, turned the key and bam! she started right up.
Is it possible for the pcm to see a low voltage battery and not let it start for this reason?
