N2o?
Old 05-08-2009, 10:38 PM
stupidfast_twin's Avatar
Default N2o?
Anyone have any idea of how much nitrous a stock lt1 can take without blowing up?
Old 05-08-2009, 10:40 PM
mj114679's Avatar
i have no clue but i am about to do a Nitrous setup my self i am going to nitrous outlet really cool people and really know there stuff... i will be checking up on this post to see if you get any real answers
NITROUS OUTLET dumdumdum!!!
Old 05-08-2009, 10:45 PM
Mr. Obvious
nightrunner's Avatar
i have heard 150shot but have no experience
Old 05-08-2009, 10:46 PM
Elliott's94Z's Avatar
Around a 150 shot. A lot of guys do the 150 with good luck. Me personally, I wouldn't go more then 100...just me though. It's one of those things where you never really know. If it's gonna go it's gonna go. I would look into the Nitrous Outlets wet plate set up if you do spray.
Old 05-08-2009, 10:49 PM
yeah, i wasnt thinking about going bigger than a 100. i want to test out a 75 shot and see how it feels. i heard about nitrous outlet, just moved out here to fort worth and the car isnt driveable cause its on an open exhaust and no insurance or registration. lol. first time using nitrous. seems like the cheapest way to make hp right now. lol
Old 05-08-2009, 10:53 PM
That's what a lot of guys do, spray the 75 on the dyno and see how the car runs then work your way up. Nitrous Outlet has complete packages they offer. You might also want to consider a new fuel pump if you spray as well. The Racetronix is a good brand. This is the bad boy right here: http://www.nitrousoutlet.com/catalog...roduct_id=2809
Old 05-08-2009, 10:59 PM
thats a bad *** kit. dont have that kind of money to spend right now. just bought some mid tubes last week and control arms. bought a nice used kit from a friend. it came with jets in it already a 038 and 052. i heard thats like a 125 shot. trying to get it running decent on this motor. gonna buile a 355 with Advanced inductions 200cc heads and manifold with a custom grind cam. ill buy that kit for that motor. lol
Old 05-08-2009, 11:00 PM
deerslayinrednek's Avatar
I was gonna run a 150 wet kit on mine, but i bought a chevelle instead
Old 05-08-2009, 11:02 PM
but dont wanna risk blowing up the motor on a 150 shot. stock short block. lol. just trying to get it decent till the 355 is ready. its still my only car to drive around.
Old 05-08-2009, 11:05 PM
A 355 with a AI 200cc package would own
Old 05-08-2009, 11:08 PM
lol, i know. i have a little grudge thing going on in california with a couple of people who think they know how to build fast motors or just get lucky and buy cars that already came hooked up. bought my car stock 5 years ago and have done little things to it. i live in fort worth now and gonna go back with the 355 on some juice and show them how to really build a motor. already got a 383 in mind and a bolt on nitrous ls1. lol
Old 05-08-2009, 11:10 PM
Fully built 383 w/ a 250 shot or a Procharger w/ the psi jacked up for the win
Old 05-08-2009, 11:15 PM
its a fully home built 383 on crappy *** edelbrock heads and edelbrock lt1 manifold on like a 150 shot. ran like a mid to high 11. ls1 is full bolt on with like a 125 shot, and no internal work
Old 05-09-2009, 08:29 PM
slp223's Avatar
I had a 125 dry shot on my stock bottom end for a long time with no problems.
Old 05-10-2009, 03:05 AM
dry shot on a stock pistons and rings? my cousins car blew up on a 100 dry shot.
Old 05-10-2009, 04:09 AM
LM97Z's Avatar
Don't run a dry shot, you really don't need a fancy high $$$$ kit, the basic 360.00 Nitrous Outlet Brand-X & a heater/window switch is all you need, along with a new pump for insurance & also a tune, if you look in the Sales section, you can come across a good kit for cheap, i got an NX big-shot kit, came with NX heater, purge, blowdown tube, FFSS, & other stuff for 400.00 bucks.
As for what they will handle, theres no real answer, but to play it safe, a 100 shot is just fine, even a 125, run some TR6s gapped @ .035", don't know what mine ran after the new clutch & N2o tune NA, but on just 100 shot it ran 12.01 @ 115.06 on the 3rd. run with a 1.80 60ft., the car was piggish off the bottle with the tune it had, so i'm sure it didn't run any better then say 13.3s @ maybe 102-103, & i know there was an 11.8 in it, so you see the gains that can be had with just a 100 shot, i though of pilling it up to 125, but it was running too good so i left it.
Old 05-10-2009, 11:42 PM
slp223's Avatar
if a 100 dry shot blew up a motor there was probbaly a fuel issue that caused the problem. ie weak bump, bad injector.
Old 05-10-2009, 11:54 PM
Z-RATED94's Avatar
My sig might help a little with your question.
Old 05-11-2009, 01:21 AM
TravisMcGill2000's Avatar
im on stock timing and i sprayed a full bottle on 150 shot. most the time im only a 125 hot. my times are in sig with a 125 shot. i kep spinning on a 150 shot. 11.8@120 with a 1.8 60ft
Old 05-11-2009, 11:21 PM
stock timing? that mean all your pistons and internals are stock too?
Quick Reply: N2o?
