Need some more opinions...
Old 05-12-2009, 05:21 PM
candyblueta's Avatar
Default Need some more opinions...
will this work with true duals w/ a Cross over "H-pipe" right uner the driveshaft??? the cross over is pretty much at the tail section of the transmission...
http://cgi.ebay.com/ebaymotors/93-02...1%7C240%3A1318
Old 05-12-2009, 05:25 PM
ss.slp.ls1's Avatar
You might have to get some custom exhaust work done. Simple answer is you won't know for sure until you try to bolt it on.
Old 05-12-2009, 05:31 PM
lol!! i knew that was gonna be said
Old 05-12-2009, 05:34 PM
ss.slp.ls1's Avatar
You should have expected it, no one knows the location and dimensions of your current exhaust set up, therefore no one can tell you if it will fit, you have to try it and see.
Old 05-12-2009, 05:37 PM
wow just realized someone made this exact post...
Old 05-12-2009, 05:39 PM
ss.slp.ls1's Avatar
LOL, yeah, but his question has a x-pipe, which you should consider installing if you have to rearrange your exhaust.
Quick Reply: Need some more opinions...
