LT1 harness swap ?
Old 05-13-2009, 09:16 PM
67LS3's Avatar
Default LT1 harness swap ?
a friend of mine bought a 95 camaro lt1 from a guy and he said the harness is from a buick roadmaster. how can i tell if the harness/ecm is obd1 or obd2? i am gm certified on obd2. my internet searches dont get much info. this swap is going into a 72 blazer with t-350 trans. i can modify the harness and tune the ecm with my efilive(if obd2 with later aldl connector. i havent looked at his buy but let me know.
Old 05-14-2009, 11:43 AM
ss.slp.ls1's Avatar
What year Roadmaster?
Does the harness have 4 oxygen sensor plugs or two?
Does it have a cps sensor plug?
Old 05-14-2009, 07:14 PM
67LS3's Avatar
i talked to the guy he bought it from. the harness is from a 94 roadmaster and the ecm is a 95 camaro.
Old 05-14-2009, 07:16 PM
ss.slp.ls1's Avatar
'94 roadmaster is OBD1. PCM is OBD1 also.
Even if you did swap to a OBD2 wire harness and PCM, I was unaware that EFILive had software available that was compatible with LT1 OBD2 PCM's.
You could always get a custom wire harness made to utilize the LS1 PCM and coil packs. Then you could tune it with your software.
Old 05-14-2009, 08:30 PM
67LS3's Avatar
thanks. you are exactly right. made me think. efilive wont do that.
Old 05-14-2009, 09:14 PM
67LS3's Avatar
when i type a vin for a 94 roadmaster lt1 and a 95 camaro lt1 in my snap-on scanner why does it tell me to use my obd2 connector?
Old 05-14-2009, 10:08 PM
goldmecham's Avatar
93-94 had the obd1 with the obd1 port under the dash. 95 had obd1 with a obd2 port under the dash
Old 05-15-2009, 11:02 AM
ss.slp.ls1's Avatar
Correct. You have to use a OBD1 scnner, like this:
http://shbox.com/1/xraycable.jpg
