What times should i be expecting on my 383?
Old 05-14-2009, 11:10 AM
killaxtranz's Avatar
Default What times should i be expecting on my 383?
ok im going with a 383 stroker with steel crank, h beams, forged pistons (not sure wat kind ima go with yet) single plane super victor intake, 210cc afr heads ported by ai, DRE shaft rockers, hydrolic rollers, planning on 90mm throttle body but might go with a 80mm, and thinking a le 230-236 cam. and really hoping for a low 11's if not in the 10's car with me driving my 6 speed. do you guys think i can get there?
Old 05-14-2009, 11:14 AM
SpeedDensityZ's Avatar
Have you called AI and asked them about porting your AFR's? I dont' think they port those.
Old 05-14-2009, 11:23 AM
i bought them ported i got the ai flow sheet... i hope i didnt get craped over
Old 05-14-2009, 11:34 AM
Maybe not. I know they don't list those on there website. I asked if they would port my AFR 190's and they said they would but, it was going to be pretty expensive. Should be a stout car. I have the AI 200cc stock ported heads and cam and I put 450 to the wheels through the exhaust and pulled 121mph before the tune which I picked up around 20whp peak on the dyno. That is enough to run high 10's with a 1.5-1.6 60' time. So you shouldn't have a problem reaching your goals. BTW what did your heads flow.
Old 05-14-2009, 03:39 PM
lift flow
.500-287
.550-301
.600-305
.600-306
.700-307
Old 05-14-2009, 03:57 PM
Very nice. I don't see you having a problem achieving your goals.
Old 05-14-2009, 04:17 PM
ABA383's Avatar
Lots of variables left on the table...Motor sounds like your headed in the right direction...gearing, suspension, weight...Its gonna be in the entire combo...
--Alan
Old 05-14-2009, 04:23 PM
ARCTIC '00's Avatar
Combo sounds like it will make good power. With the right converter/trans & suspension I don't see why 10's wouldn't be feasible.
Old 05-14-2009, 05:53 PM
supention i plan on running qa1 shocks and springs i got ebachs on it rite now and i dont really care for it. also ive riped the whole ac unit outa the car and will probly be running close to stock weight.
Old 05-14-2009, 06:22 PM
ARCTIC '00's Avatar
QA-1's are definitely an upgrade for the strip over Eibach's.
Old 05-14-2009, 10:20 PM
also i am kinda wondering if that 10 bolt will hold up im pretty sure i bought teh car with 4:10 gears a freind of mine told me how to tell but i forgot. you think it will hold atleast 2 months after i get teh powerpant built?
Old 05-14-2009, 10:54 PM
Wicked94Z's Avatar
just dont go to the track
Old 05-15-2009, 01:36 AM
BADMOON's Avatar
WTF
Old 05-15-2009, 09:42 AM
yea ima go with hydrolic instead of solid and wanting to go with the 90mm tb with the single plane..
