My carbed LT1 build, need yalls opinions
ENGINE 1996 LT1 from camaro
Heads: Trick Flow LT1 aluminum, 2.02 1.60ss valves, beehive springs
195cc 68cc 72cc 3/8 arp rocker stud
comp pro magnum 1.6 self-aligning rockers,pushrods,lifters
Intake:GM LT1 carbureter conversion, aluminum dual plane, or a single plane victor jr. in the works real soon
Fuel: Holley 750 vacuum, all choke accessories were removed
Ignition: converted from optispark to HEI, MSD cap,rotor,wires, pertronix flame
thrower coil, module, comp gear
BottomEnd: all forged 383ci scat rotating assembly
Timing chain: cloyes tru roller double roller
Camshaft: comp cams "xfi" hydraulic roller 292/300 advised duration
584/579 lift, 113 lsa, designed for beehive springs
Cooling: northern aluminum radiator,16" electric fan w/aluminum
shroud, CSR electric water pump, 160 thermostat
Balancing: internal balanced, with new Proffessional product balancer
Exhaust: "dougs" 1 3/4- 3" ceramic headers, 2.5" pipe, custom "flowmaster" style mufflers
TRANNY
TH350 stock case,fully built internals, 850$ worth
havent found the right converter yet...
REAREND
stock (for now) 8.5 10-bolt with spool, 3.90 gears
no subframe connectors, or traction bars yet, im goin to install a rear coil over kit and get rid of the springs eventually, so tell me what ya think guys
TRANNY
REAREND
oh yea. how selfish of me lol...here arw plwnty of pics from my myspace, enjoy..
http://viewmorepics.myspace.com/inde...ndID=451618024
I'd also stay away from self aglining rockers. Get some NSA rockers and guide plates, the heads are already studded, so its not a big deal adding guide plates.
Reason I suggest it, is I have heard that with higher lift cams they don't work out very well.
Other than that it sounds like a badass build, be sure to post up lots of pics
Advertised duration is the angle in crankshaft degrees that the cam follower is lifted more than a predetermined amount (the SAE standard is 0.006") off of its seat.
reference: http://www.lunatipower.com/Tech/Cams/CamSpecTerms.aspx
Your used to reading durations that are measured at .050
you have to have self alighning rockers for centerbolt valve covers so im told, it already has guides too..ill have pics when i start it
that is advised duration.
Still a good sized cam man! should be a beast.
Good luck with the build man, I have just heard to stay away from SA rockers with higher lift cams to avoid troubles
BTW a buddy of mine has a '73 Nova SS with a 502 and a 6 speed and I just love that car. I'll see if I can dig up some pics of it and post them up
I still have centerbolts and I have guideplates, hardened pushrods, and 1.6 NSA pro mags under the stock covers. I had to trim the insides of the covers to make them fit, but its really easy to do.
well these rockers are brand new and i dont have the extra cash to waste on anothr set so ill c how these do
yea id love to see anothre 73 ss, im sure its a beast
But my buddies car is crazy. It started out with a small block and a th350, then the big block, then a reverse valve body th400, then some spary (75 shot IIRC) and low 10 second quarter mile times on a 26x9 et street tire (A 10.2 was his best), and now its on all hotchkis suspension and 17" boyd cottington wheels with a 6 speed and still has a little spray
The car is really nice, but if it was mine there would be a few things that I would change, but thats all personal preference.
I like your car though, still with the old skool stance and classic wheels....it looks really good, but lowered with a set of ZR1s......now that I think would look badass
