Need help on strange noise ASAP *vid included*
Old 05-14-2009, 11:46 PM
13lu91rS's Avatar
Default Need help on strange noise ASAP *vid included*
cant exactly locate the noise, wherever you go to listen is where you hear it at. sounds like a hollow really loud screetching sound. i'll let you listen and maybe you guys can guess.
had a friend of mine with a c4 that said his opti did this in his vette. but not sure.
http://www.youtube.com/watch?v=_Kut0ohMy8E
and its stuck at buddys house, so as soon as i can figure out the problem i'll be able to get it out of his driveway.
Old 05-14-2009, 11:51 PM
Purple95Z28's Avatar
Does it run OK? Can't really hear the motor but it seems like it's running rough judging by how much it's shaking. Is the oil pressure good? Do all the pulleys appear to be spinning normally? Try pulling the belt off and start it briefly just to see if it still does it.
Old 05-14-2009, 11:58 PM
litch2004's Avatar
mine made that exact noise when my flex plate was hitting my starter. my flex plate was unbalanced causing it to move and hit it.
Old 05-15-2009, 12:06 AM
13lu91rS's Avatar
i have an m6, and its running rough becuase i just put new lifters and pushrods in the car and tried adjusting the rockers but couldnt hear over that awesome sqeakin noise.
Old 05-15-2009, 12:11 AM
litch2004's Avatar
but what im getting at is that your flywheel could be hitting the starter. It was the same noise i hear on mine. It wouldnt hurt to look at your bendix gear on the starter and see if you notice any wear.
Old 05-15-2009, 12:12 AM
litch2004's Avatar
when the rpms increase the intensity and quickness of the noise increased as well.
Old 05-15-2009, 12:25 AM
13lu91rS's Avatar
alright man i apreciate it, i'll have to check tomorrow.
any other suggestions would be awesome
Old 05-15-2009, 04:56 PM
litch2004's Avatar
any luck?
Old 05-15-2009, 05:03 PM
SoxXpupPeT's Avatar
wow that sounds..... broken. sorry no advice for me to give on this
Old 05-15-2009, 08:00 PM
3rdgen92maro's Avatar
Tony its a turd just junk it...LOL
Old 05-15-2009, 08:06 PM
Kmaroman's Avatar
Here's a few things to try, take the valve covers off check everything out. Hell it may be hitting the valve cover to much lift? Spray some lubricant on the belts an pulleys. Even though it didn't sound like an exhaust leak check the bolts holding ur headers/manifolds on? Check the spark plugs out to, any trouble codes?
Old 05-15-2009, 08:45 PM
13lu91rS's Avatar
no codes, that vid is also with the valve covers off.
had someone hear it over the phone and said could be crank bearing. if thats the case than a h/c 355 with full bmr suspension and a 12 bolt will be going into the car.
that or go buy an ls1 car?
Old 05-15-2009, 09:54 PM
red-_-z28's Avatar
mhmmm cracked flexplate or spun bearing or even bad torque converter
Old 05-15-2009, 10:10 PM
Ironxcross's Avatar
Try and locate the sound. Go from there.
On my 97 the opti never made any funny noises before it died. It just conked out one night.. that was it.
Old 05-16-2009, 04:42 PM
FlamingChicken's Avatar
did you try taking the belt off? always hard to diagnose without being there but almost sounds like a pulley is seizing.
Old 05-16-2009, 05:24 PM
SoxXpupPeT's Avatar
i didnt even think of that! id do what he said first! my dads alternator on his 95 9C1 lost both of its bearing the same day. the noise was so unbelievable that you couldnt hear yourself think
Old 05-16-2009, 08:26 PM
13lu91rS's Avatar
yea guys. that vid is with the valve covers off, no alt. and of course no belt. car is running on battery only in the vid.
Quick Reply: Need help on strange noise ASAP *vid included*
