Priming oiling system...
Priming your oiling system won't cause any problem.
There isn't enough oil spash to effect the sealant and there won't be any crankcase pressure buildup either.
I always prime until I see oil squirting from each rocker arm with NO air coming out. This calls for intermittently and manually turning the engine as I prime.
Jake
West Point ROCKS!
Jake
West Point ROCKS!
Another option is to disconnect your coil, pull the fuel injector fuse, and crank the motor over until the oil pressure comes up (that's what I did for my heads/cam swap - which may be different due to the rod and main bearings already having oil in them...)
