95 TA Convert to T56 can i use 96 computer??
Old 05-18-2009, 06:15 PM
Black96transam's Avatar
Exclamation 95 TA Convert to T56 can i use 96 computer??
ima drop the motor n tranny back out... ima put the t56 in out of a 96... think i can use the pcm out the 96 in the 95 body??
(95 is OBD1) (96 is OBD2)
Old 05-18-2009, 06:36 PM
ss.slp.ls1's Avatar
The beautiful thing about switching to a manual transmission, is that it's manual (duh) no computer involvement whatsoever. Just keep the same computer you have and flash the PCM to a manual trans tune. Or just ignore the 12 or so codes that you'll throw after the swap.
Old 05-18-2009, 08:31 PM
i can flash the computer to manual and disable the automatic tune?
Old 05-18-2009, 08:33 PM
RamAir95TA's Avatar
Technically you don't have to disable anything. Just have the codes programmed out. It's that simple.
Old 05-18-2009, 08:42 PM
thas kool... i'm not much on the computer stuff... im more of an old school man... haha... trying to step up my knowledge...
Quick Reply: 95 TA Convert to T56 can i use 96 computer??
