any1 tried these ebay headers?
Old 05-18-2009, 09:40 PM
93cz28's Avatar
Default any1 tried these ebay headers?
any1 running these? summary on em plox.
http://cgi.ebay.com/ebaymotors/93-97...Q5fAccessories
Old 05-18-2009, 10:12 PM
Counted Out's Avatar
Good price. Stainless too.
I know some people have luck with eBay headers on LS1's, but I've never heard anyone with an LT1 having them.
Old 05-18-2009, 10:48 PM
blkZ28mara's Avatar
I am also wondering about these.
Old 05-18-2009, 10:52 PM
A20SVT00's Avatar
yea i bought the ones for ls1 and they are nice and my buddy bought some for his vette no promblems at all i say they are worth it
Old 05-18-2009, 11:01 PM
za355tx's Avatar
They actually look just like the LPP headers.
Old 05-19-2009, 12:03 AM
93cz28's Avatar
i thought the same thing. I messeged some guy that ordered a set on ebay to see how they are but he said he hasent received em yet.
Old 05-19-2009, 12:18 AM
sdotlog's Avatar
damn only if they made sets like this for b-bodies =/
Old 05-19-2009, 12:29 AM
tspence45's Avatar
I'd consider them if you could get them without the y-pipe. There's no way I'll ever run a y-pipe again. Looks like a hell of a bargain for LS1 guys. You get them for a few bucks over $200, without the Y.
Old 05-19-2009, 12:38 AM
za355tx's Avatar
Yeah they looked stepped too even though they don't say anything about them being so. The gaskets are even the same. The only difference I see is that these are made from 304 stainless instead of 321 like my LPP's are. Spence I know what you mean about the Y pipe I got one with my LPP's but it doesn't look like I'll ever use mine. I'll hang on to it though just in case.
Old 05-19-2009, 04:33 AM
You should keep us updated on that.
Old 05-19-2009, 06:27 AM
z28rob18's Avatar
i believe someone with username creepingdeath used ebay headers and said that the steering knuckle needed to be moved some
Old 05-19-2009, 06:37 AM
IROC-Z28_CAMARO's Avatar
I was thinking about these as well since LPP is taking way to long for there second batch.
Old 05-19-2009, 07:11 AM
creepingdeath94's Avatar
I have them. I got them from "PitStopTuning" though, but same supplier. They are stepped, good thick polished stainless, good welds...overall great set for the money...$440 shipped!? That's pretty damn good if you ask me for long tubes, the ORY, and hardware and clamps. I will tell you this though, they have to be fitted and probably a bit more than the LPP's. You probably need mroe patience and tooling/welders/cutting equipment for grinding etc. in some cases with these as the standards for specs are probably not as strict between sets like they are for LPP I'm sure. I had to do some work to get them in there, but overall, a couple slow paced days messing and tinkering wasn't too bad for what all had to be done.
I had to grind the steering knuckle some, the K-member, and cut a pie slice out of the ORY in a spot to bring the angle in some to get it away from my body some...probably didn't have to, but I am **** about fitment/rubbing/how it looks. It all was not bad, but tooka bit of time for each thing. I also later replaced my motor mounts and that helped some, so if you need to replace them, that would be the time. Also, do yourself a favor and remove the coolant temp. sensor off the drivers side and the oil press. sensor off the oil filter housing if it is down there on your application so you don't break off the sensors during installation like my dumb ***. Also, I had to remove the oil cooler that was on the oil filter housing...some cars may or may not have this...but it had to come off for the oil filter to go back on.
This all sounds like a lot, and it is, but all LTs are a pain and take time, these are great for the $350+ I saved on them from other stainless suppliers.
Old 05-19-2009, 07:12 AM
Why wouldn't you run the "y"?
Old 05-19-2009, 08:33 AM
Hawk465's Avatar
I would hold off, I just got a PM saying the LPP's are in production right now. I was going to order some Pacesetters this morning, but decided to give it a little more time.
Old 05-19-2009, 03:26 PM
tspence45's Avatar
Because I've got true duals, with an x-pipe. I'll never go back to a Y. The rasp is unbearable.
Old 05-19-2009, 07:05 PM
93cz28's Avatar
well i couldent wait so i just ordered em =). ill have pics up when i install em.
Old 05-19-2009, 08:28 PM
Understandable...I am getting pretty sick of the rasp myself. Unfortunately I don't have the means to do anything about for a long time :-(
Old 05-19-2009, 08:43 PM
ls1adamls1's Avatar
i ordered these a few months back but have not had the time to install them. they look great but im worried about how they will fit. im probably doing them this weekend
Old 05-19-2009, 09:05 PM
LPP always says they are in production. Are these 1 3/4 to 1 7/8 steped and do they use a merge collector?
Quick Reply: any1 tried these ebay headers?
