Car just died on me while driving
Old 05-21-2009, 09:28 PM
  #61
Green3spd's Avatar
Originally Posted by 2XR95Z28
not seeing how to check the opti on the first or second page...
any help?
I dont see it either...?
Can you put a spark plug in the wire OUT of the motor and check it that way..?
Old 05-21-2009, 09:31 PM
  #62
2XR95Z28's Avatar
thats what i have always thought....
Old 05-21-2009, 09:48 PM
  #63
Green3spd's Avatar
did u try that..?
Old 05-22-2009, 12:32 AM
  #64
2XR95Z28's Avatar
tried, but its a little tough with one person lol. Need another person to crank it over while i watch the plug. Will try to do that tomorrow...
Old 05-22-2009, 02:03 AM
  #65
airfix's Avatar
http://shbox.com/1/4th_gen_tech2.html#opti_test
Dunno if this will help you out, hopefully.
Old 05-22-2009, 11:00 AM
  #66
2XR95Z28's Avatar
Guess i'll have to find a meter thing lol, I'm not good with all that electrical stuff but will try to get my buddy who is to help me out. Thanks for the link airfix
Old 05-22-2009, 01:33 PM
  #67
airfix's Avatar
no prob dude, good luck.
Old 05-23-2009, 06:19 PM
  #68
Speedy's Avatar
I'm having the exact same problem. Trying to track it down right now. Spark from coil, no spark at plugs. Brand new opti, icm, tps, fuel is good. Anyone had problems with MSD coils blowing out optis? Just wondering if the extra voltage is killing it.
Old 05-23-2009, 06:35 PM
  #69
robsquikz28's Avatar
you know what i saw a thread here before with the msds killing the optis but many peeps have been running them for a long time including myself and im fine..but i would say if you have power out of the coil wire then you know your coil works but now you can have some one crank the car and jam a circuit tester aka test light into any spark plug wire BOOT on the opti . dont poke the wire just slip it in the boot and try to touch the conductor for the wire and yes connect it to ground, while your buddy cranks it over for a very short time it should light up indicating it has power going to that plug wire but you have 7 other wires to check and thats hard to do because of all the accessories in the way..but the opti may be bad even if you get spark, or a screw fell out of the opti, or even burnt the cap where there will never be spark at that cylinder..but if there is no spark then yes your opti can be bad, but u then need to check for power to the opti before replacing the opti sux too
Old 05-23-2009, 09:46 PM
  #70
bad_408_vert's Avatar
Default Look into ICM
sorry for some of what of
I had similar problems with my 01 3.8l.
I ended up replacing coils, coil housing, icm, crank sensor, map sensor.
The car's been good for a year now this bs started all over again.
I am troubleshooting this same bs this weekend .
I been followin this thread and I 'd say check the icm.
Old 05-24-2009, 08:38 PM
  #71
Green3spd's Avatar
Ok so i pulled out of work today got on the gas about half throttle and then the car just shut off, no loud sound of anything just died, tried to re-start it but it just cranks and cranks and won't fire over. Started fine in the parking lot at work then randomly dies and now won't re-start...
Thinking spark? Just replaced the plugs two days ago with tr55's. Coil has less than prolly 50 miles on it. Got the opti from Larry from Speed Inc, he said it has very very low miles on it. I'm lost lol...
Any suggestions?
When my opti went out, I was pulling out of work, it just quit.. Im leaning toward opti for you now..
You did check opti pigtail right? like I mentioned for the 3rd time now..? lol..
Old 05-25-2009, 11:57 PM
  #72
2XR95Z28's Avatar
ya i checked the pigtail and it looks perfectly fine... Havent messed with it in the past few days but will take another peak at it this week but i'm ready to just drop it at a shop and not mess with it anymore lol. I'm gettin fed up with all the problems i've been having lol.
Quick Reply: Car just died on me while driving
