High Pitch Squeal In Wet Conditions
Old 05-31-2009, 02:04 PM
Marc3.4V6's Avatar
Default High Pitch Squeal In Wet Conditions
This happened sometimes with the stock hood, but since I just got my cowl induction hood, sitting overnight it was way too loud to drive when I started it up this morning.
What should I look into? Alternator bearing, belt, pulley? I'm thinking something is worn out and ordinarily I should be able to leave it parked in heavy rain and it still wouldn't be like this.
Old 05-31-2009, 02:07 PM
Puck's Avatar
If you have dried grease spots on your belt humidity and moisture will make it squeek and squeel. First check to make sure your tensioner is working and the belt is not loose, and if it looks tight then try cleaning your belt with some belt dressing and see if it helps.
Old 05-31-2009, 03:17 PM
Marc3.4V6's Avatar
Sprayed the dressing on it, went away for about 45 seconds, them came back. Repeated it, same thing. I'm going to try a new belt first, then go from there.
Old 05-31-2009, 03:27 PM
BigBirdLS1's Avatar
Have you checked your pulleys it could be a bad pulley bearing. You can take off your belts and spin them with your hand if its hard to spin or there is a lot of play that is probably it.
Quick Reply: High Pitch Squeal In Wet Conditions
