crankshafts ???
Old 05-31-2009, 08:48 PM
saylorZ28's Avatar
Talking crankshafts ???
what are the difference in lt1 crankshafts and gen1 sbc 1 peice rear seal crankshafts having a hard time finding and forged crankshaft for lt1 . i'm planning a 355 or 383 getting my block work done now need help with this i also read alot of problems with cast cranks and wonder if anyone has problems with the forged... also what can i spin a all forged 355 or 383 to safely ... with n20
Old 05-31-2009, 08:49 PM
RamAir95TA's Avatar
As long as it's for a SBC with a one-piece rear main seal, it will work. There are no LT1-specific crankshafts.
Forged is always the way to go for N2O/boost.
RPM limit depends on a lot of things. If we rule out the valvetrain, transmission, a budget, and everything else, you could build a bottom end to survive spinning to the moon.
Old 05-31-2009, 09:06 PM
saylorZ28's Avatar
kewl well i was goin to used forged h beams and forged pistons .. i got comp magnum rr 1.6 ratio magnum one peice push rods if i do the 355 i was thinkin bout goin back with the 503 or gm 847 duno but has anyone every done a 4 7 swap cam in a lt1 do they make it i know they do for sbc but lt1 being efi i duno it would be fairly straight forward swap 4 7 injector and plug wires ... ?
Old 05-31-2009, 10:20 PM
My95Z's Avatar
Valve springs should be near the top of your list as a limiting factor for high rpm's. Most 4340 forged cranks are rated up to around 8k rpm, but thats just he crank and they all are different.
4-7 swaps do not work well with the LT1, it has to do with the intake and making certain cylinders run lean. Sorry I don't remember the specifics as to which cylinders got worse, but overall disadvantages outweigh the advantages when using an LT1 intake.
Old 05-31-2009, 11:05 PM
strokin93z's Avatar
There is also small and large journal sbc 1 piece cranks... Just another factor i believe.
Old 06-01-2009, 12:02 PM
saylorZ28's Avatar
small and large should i be concerned about that and what does that do just supply more oil ?
Old 06-01-2009, 01:16 PM
My95Z's Avatar
No, you want large journal it has to do with the size of the crankshaft where the rod connects to it. Idk if they even made small journal 1 piece I thought they were all 2 piece.
Old 06-01-2009, 02:10 PM
saylorZ28's Avatar
now i am confused lol...
Old 06-01-2009, 03:47 PM
My95Z's Avatar
You want a large journal, 1 piece rear main steel crankshaft. Thats all you need to know lol.
Old 06-01-2009, 05:30 PM
97Z28SS's Avatar
Google Compstar it's Callies line of budget 4340 forged cranks and rods and they are plenty stout for whatever you're trying to do.
Quick Reply: crankshafts ???
