View Poll Results: What do you think will be the out come
No - The security light will come on
0
0%
Multiple Choice Poll. Voters: 9. You may not vote on this poll
Has this happend to ANYONE with there car before EVER !!!!!
Ok, so a few weeks ago my car check engine light came on right before i went to the track and it went from a 12 sec car to running 14.0 trapping anywhere 8-11 miles slower. OBD TECH 2 showed 4 codes
p0100 p1657 the other 2 had to deal with o2 sensors , skip shift 1-4 then it was blowing the fuse in the engine sensor
since then i had it checked out to see if any electrial wires toasted they couldnt find anything. So they put in a 25 amp breaker fuse in.
so the car runs like crap then all of a sudden a week later the electric water pump goes out. I put a new one in and we noticed the electric water pump was connected to the pcm . So i bought a new electric water pump the car ran for 4 minutes then it died then the SECURITY LIGHT came on BLINKING the car woudlnt start at all. I contacted bryan @ pcm4less told him everything and he said flat out your PCM is F$C^E% so i managed to find one after searching all over the internet nobody had one called gm got the only one in the state threw brown and brown cheverlot in AZ. $208 bucks not bad. Its been sent off i should have it in 2 days.
Heres the question im having the VAT turned off do you think the car will start up or will the security light still be on and i wont be able to start the car ?
This isnt a tech question really im curious if anyone else has experienced the same
yes somewhat the same issue in my car is sig......the #6 fuse in th engine bay fuse block kept blowing causing the fans not to turn on and a whole buch of other stuff. i looked all over for loose grounds, bare wires and the whole 9 yards but could not find anything. So then i thought to myself let me replace the PCM which i had one laying around so i installed it and bam the problem was gone!!!! damn PCM was Screwed!
ok heres a story that might help i go to get in my 95 formula and i put the key in and it does nothing wont even turn over so put a switch in didnt fix it, turned vats off didnt fix it but finally i found a relay/fuse think behind the dash on the passenger side and hooked two pieces of wire together and it fired up but the secrutiy light is on but after 5 minutes of driving it goes away
Yes when the security light came on i heard clicking coming from behind the glove box.
may i ask you this how do you get to it and what should i be looking for.
any help with be greatly appreciated !!!!!
1. what should i be looking for
2. where exactley is it located at
3. once found what do i do ?
Here's some vats info, it helped me fix my car just the other day. Hope it helps you too. I do not see how the vats would make it run different, but it' worth looking at because a security light is a vats issue as far as i know. So read it all, you will learn a lot and might even fix something lol.
http://shbox.com/1/pass_key.html
This is coming from a firebird so it may be a little different on the camaro's. Mine is located on the metal bracing inside of the dash, to the right of the glove box. I am able to reach these by dropping the glove box and then reaching around the bracket to the backside. Mine was a gray relay. There were two of them side by side. Not sure what the other one is though.
