Low oil sensor plug
Old 06-02-2009, 01:45 PM
Airplanedoc's Avatar
Default Low oil sensor plug
I tried to install my LPP header and found they won't fit with my canton oil pan if the low level sensor is installed, now I need a plug to remove the sensor. Where do I find one?
Thanks in advance
Old 06-02-2009, 01:47 PM
Schweet97Z's Avatar
http://thunderracing.com/catalog/?ac...&vid=4&pcid=84
Old 06-02-2009, 01:58 PM
Thanks for the help I just ordered one.
Old 06-02-2009, 02:57 PM
Schweet97Z's Avatar
no problem.
Old 06-02-2009, 03:11 PM
djjab57's Avatar
AZ has them, thats where i got mine from
Old 06-02-2009, 03:23 PM
goldmecham's Avatar
im with this guy ^^^
Old 06-02-2009, 04:15 PM
tonskiguy's Avatar
Is that Aut0 Z0ne? Having trouble finding it.
Old 06-02-2009, 04:39 PM
djjab57's Avatar
yes auto zone, they have sockets for all the sensors
Old 06-02-2009, 07:12 PM
goldmecham's Avatar
the one i got was in a bin behind the counter.
Old 06-02-2009, 07:33 PM
tonskiguy's Avatar
Not the socket, but a correctly threaded plug to replace the sensor.
Old 06-02-2009, 07:47 PM
goldmecham's Avatar
its a oil drain plug 18mm if i remember right. they had it in a bin behind the counter if not napa should have it.
Old 06-02-2009, 08:05 PM
tonskiguy's Avatar
Sounds good, I think it's a 20mm, I'll go check it out. Thanks!
Old 06-02-2009, 09:18 PM
tonskiguy's Avatar
No luck at the Zone, biggest oil drain plug they had was 14mm. The Thunder Racing one is $20 by the time you pay shipping. Any other ideas?
Old 06-02-2009, 09:24 PM
the_merv's Avatar
20mm..is it a 20X1.5mm?
If so then you can get it at Auto Zone.. it's the same thread of the one that i used to block off the T56 Skip-Shift Solenoid..
