o2 sensor
look for the wire loom on the driver side that plugs into the oil level sensor and oil pressure sensor trace that to the loom and a 4 wire will come off it with a flat plug. the pass side look for the loom by the motor mount where the knock sensor and starter wire comes out should be there and its a 4 flat as well.
