Wiring Mystery??? Please help!
Old 06-03-2009, 06:19 AM
chevydriverz28's Avatar
Default Wiring Mystery??? Please help!
I was went to crank my 1996 Camaro SS LT1 OBDII car today. When I turn the key the gauges dont move, the starter wont even make a peep, and the fuel pump never primes. I have a walbro pump so I know what that thing sounds like. Is there something in line that disables all three of these items if messed with. All my fuses are solid inside and out. Please help me if you can!!
Brandon
Old 06-03-2009, 06:53 AM
meissenation's Avatar
Sounds like your PCM has no power. When it has no power, the fuel pump will not prime. Do you have any power at all to anything?
Old 06-03-2009, 07:23 AM
shbox's Avatar
If your headlights work, then it's probably your ignition switch.
http://shbox.com/ignsw/ign_switch_repl.html
Old 06-03-2009, 09:21 AM
litch2004's Avatar
VATS maybe
Old 06-03-2009, 09:37 AM
Green3spd's Avatar
Old 06-03-2009, 10:19 AM
duh
duh's Avatar
Originally Posted by litch2004
VATS maybe
If it were vats the gauges would reset and not do a thing...then the security light keeps blinking....and blinking....and blinking....but the car doesn't start...
Listen to shbox, he has yet to steer in the wrong direction.....
