Brace bolt size?
Old 06-03-2009, 07:45 PM
ss.slp.ls1's Avatar
Default Brace bolt size?
I tried searching.
I need to get some grade 8 bolt's for my Spohn tunnel mount TA cross brace. I removed the stamped steel cross brace long ago so I have no bolts to compare the new ones too. Anyone know the thread pitch off hand?
Old 06-04-2009, 11:52 AM
RamAir95TA's Avatar
I ran into the same problem. It's a pretty common pitch if I remember correctly. I had some leftover bolts from something that worked fine.
I know that doesn't help you much but eh...it's a common pitch.
Old 06-04-2009, 12:03 PM
ss.slp.ls1's Avatar
I figured it out. It's a M8 1.25 if IIRC.
I needed ones at least 30mm long to have good thread engagement through my cross brace and my 3-point SFC's and using both a lock washer and a flat washer.
Quick Reply: Brace bolt size?
