Single plane Intake
Old 06-04-2009, 07:51 PM
Anthony0908's Avatar
Default Single plane Intake
I have searched
I want to know what holes on the intake have to be filed and where to drill the new ones.
What should I expect to spend if I go to a machine shop and ask them to do this.
Old 06-05-2009, 11:25 AM
Some one knows.
Old 06-05-2009, 12:58 PM
ulakovic22's Avatar
If you are talking about bolt mounting holes, the 4 in the middle need to be relocated and drilled with the correct angle and pad. You can get away with drilling them straight and then using a shim under the bolt head. Not sure on the cost to convert but any machine shop should be able to do it. Price depends on too much to quote. I would guess no more than a 100 or so just for the bolt holes though.
Old 06-05-2009, 01:14 PM
So I take it if I take a LT1 intake gasket that should show me where to tap and drill the hole?
Old 06-06-2009, 01:08 AM
slownova73's Avatar
yes....
Quick Reply: Single plane Intake
