Fuel Tank Heat sheild delete?
Old 06-07-2009, 06:54 PM
Hawk40's Avatar
Default Fuel Tank Heat sheild delete?
backing out of my steep driveway has taken its toll on the heat sheild that is between the muffler and the fuel tank. does the muffler ever get hot enough for it to matter? or is this just safety engineering overkill from GM
i'm going to have to either try to bend it back into shape or remove it and i think removing it will look much better.
Old 06-07-2009, 07:09 PM
Nelapse's Avatar
It's more than a heat shield, it is a layer of protection for your tank as well. Keeps the things you accidently run over from puncturing your tank.
I would keep it in. It weighs maybe 2 lbs.
Old 06-07-2009, 07:37 PM
Hawk40's Avatar
i wouldnt be removing it for weight loss...like i said..its bent up so it looks bad...but its also rattling constantly...driving me nuts
Old 06-07-2009, 07:44 PM
Built LT1's Avatar
I removed all of my heat shields with no problem.
For what it's worth, STS Turbo says the heat shield is plenty to prevent too much heat from building up under the tank.
Old 06-07-2009, 07:57 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Trash can. I removed all of the ones under my car. It is a win win situation as you are loosing weight and removing an annoyance.
Quick Reply: Fuel Tank Heat sheild delete?
