will a ls6 intake work on a lt1?
unless you are making 400rwhp from your heads and cam combo, which obviously you are not, stay away from doing anything to your intake. sounds like your mechanic friend is trying to mix the old school with the new school - I wouldn't ask him for anymore advice
yeah unless he tells you to rotate your tires or something like that
im building an engine that is borred 30 with a 280-288 comp cam hydralic lifter an valve spring kit, with 1.6 roller rockers an im trying to find a better than factory intake
LT4 heads and Intake arent really any better than the stock LT1 heads/intake. The LT4 stuff tends to have alittle more advantage when ported, however the cost to find a set, your better off just going with AFR, Trickflow, etc....
Just an FYI its a 230/236 duration cam @ .050" which is what everyone goes by in terms of specs. But I do feel you made a decent decision on the cam. Should work well with supporting mods, such as headers, exhaust, intake, 52mm tb, etc... What springs and rocker arms are you going to be running? As well as pushrods?
http://www.compcams.com/Cam_Specs/Ca...csid=1111&sb=0
i havent ordered any push rods yet but the hydralic lifters and valve springs came in a kit with the cam. i have aluminum 1.6 roller rockers. i know im going to get some headers but i havent decided on them yet neither, i plan on getting a lot of add ons
Great. Just make sure you do your research before you buy. Make sure you know what your getting. Also dont buy into the advertising that companies put out to sell their products. If your unsure of something post up and everyone on here will stear you in the right direction.
