What should i run in the 1/8th
If you can hook I'd give you 8.0's maybe high 7's. But you need to hook. Do you have good DR's?
My buddy with a hotcam kit and light head porting ran 8.3's on street tires so with your setup I'd think you'd prolly have him by about .5 with DR's.
With my mods in my sig I ran consistant 8.1's on 255/16 bfg drag radials and still wasnt hooking up that was with stock untouched heads. I just recieved my set of LE2 heads, Im not sure how much they will improve my time.
You should be high sevens Id imagine depending on how good of driver you are, and tires.
Alright thanks guys. I am ordering the 1.7s and a 52 mm TB this weekend along with taking my heads off and sending them in. Then getting it tuned with PCMfor less...just wanted to know what kind of times i should be putting down.
Yea i know i used to know how to figure the amount of lift from 1.5-1.6-1.7
Could anybody tell me what amount of lift i would be at...and if it is too much
Thanks for all the help i cant wait to get this stuff ordered and in..
I would hope u do better than 8.4 with your setup. I can do 8.4 all day with my bolt-on car and I'm on the slower side of full bolt-on car around this site. I know I've got a fairly light car but a LE2 H/C should more than make up for that. I would expect high 7s till you get her all figured out even with an avg 2.0 60ft time.
You should go mid-high 7's at the worst. My bolton car goes 8.3's soon to be 8.0's or so with a converter. Since your a H/C car, there is no reason that you cant hit 7's unless something isnt running right with your setup.
