What tools will i need for my gear swap??
Im using this kit to go from my 3.23's to 3.73's. What tools will i need to do it? Iv got about evry tool you could think of, but this is one thing iv never done. I need like a dial indicator and some other **** right?
http://www.summitracing.com/parts/CM...1/?image=large
Must haves:
Hydraulic press for removing and installing bearings.
Dial indicator as mentioned by /\
Brass punch or other tool for installing pinion bearing rings in the housing
Jack handle and breaker bar for getting extra leverage to crush the crush sleeve
Pinion nut socket (1.125") IIRC.
Gear marking compound
Optional:
Air tools and especially a 1/2 impact
Pinion depth setting tool
Optional:
Last I checked around out here it was like $250 for an install....IMO alot cheaper to do that then have a car torn apart and a big headache of getting it back together. A competent shop should get it done in a day. Make sure to find someone good though, otherwise you run the risk of a noisy rear, and that's not fun.
Must haves:
Optional:
Optional:
