Changing O2 sensors
Old 06-11-2009, 03:25 PM
nik1703's Avatar
Default Changing O2 sensors
Hey guys,
So I was told that the rear O2 sensor near the cat does not effect A/F ratio, but only determines the efficiency of the cat. Is this correct?
So, I really only need to replace the front O2 sensor if my car is running rich? Also, WHERE is the front one?!
Thanks guys.
Old 06-11-2009, 03:31 PM
ss.slp.ls1's Avatar
I thought '93's only had the front pair of o2 sensors Even if you had post-cat o2 sensors, you only have one cat, so you'd only have one rear o2 sensor...
Yes, post-cat o2 sensors only serve to measure the efficiency of the cat.
For the front o2 sensors you should only be running AC Delco's.
Old 06-11-2009, 03:32 PM
nik1703's Avatar
I don't know honestly. lol
Old 06-11-2009, 03:49 PM
infinitebird's Avatar
Yes, 93s only have front ones. They are located on the exhaust manifolds or headers.
Old 06-11-2009, 03:54 PM
nik1703's Avatar
So for my car, both O2 sensors effect the A/F ratio?
Old 06-11-2009, 03:55 PM
yes, each one controls 4 cylinders.
dkishton1486's Avatar
Yes because you only have 2 O2 sensors
Old 06-11-2009, 04:21 PM
nik1703's Avatar
running rich - O2s are the culprit on a 93'? (no MAF)
Old 06-11-2009, 04:27 PM
ss.slp.ls1's Avatar
How many miles are on them?
Old 06-11-2009, 04:30 PM
nik1703's Avatar
god only knows
Old 06-11-2009, 04:34 PM
ss.slp.ls1's Avatar
god only knows
Then get a new pair of AC Delco's then.
