Moroso problem with pick up tube wtf...
OK so i am installing the moroso 20185 oil pan and have a melling 55 oil pump and the pan dont fit...so i ordered the moroso pick up tube that it suggests for the car which is 24212 and guess what it dont fit either now wtf
the pump is stock size of 3/4" and this pump is 5/8"
i called moroso they said they dont make a 3/4" pick up tube. so now what do i do, what have you guys done???????????
i need the right pick up tube now and this is whats holding up my project
i had this same problem and went around in circles with summit and moroso. i asked the tech from moroso if there would be a significant difference in flow from dropping to a 5/8 and he said it should be ok. i was like what the hell does it should mean when we are talking about a critical system. ended up getting summit to take back the pan and pick up and bought a canton. much better in my opinion.
