What is the minimum safe distance that exhust pipes should be from steel fuel lines?
Old 06-13-2009, 04:46 PM
wrd1972's Avatar
Default What is the minimum safe distance that exhust pipes should be from steel fuel lines?
What the subject says.
Old 06-13-2009, 05:23 PM
Schweet97Z's Avatar
I dont think is a spec per say....however I wouldnt have them too close. its more a common sense thing. I wraped my fuel lines in header wrap on the drivers side where the Y-Pipe gets close to them....
Old 06-13-2009, 05:33 PM
strokin93z's Avatar
/\ +1. if you feel you are getting to close, just wrap them. Maybe make a shield for them.
Old 06-13-2009, 05:47 PM
wrd1972's Avatar
I am going to wrap them like you guys said and try to make a shield. I guess its just the engineer in me that is looking for a target distance to play it safe.
Old 06-13-2009, 06:21 PM
strokin93z's Avatar
1.40612" away from the fuel line is minimum. Ive read that somewhere. It also depends if the system has cats before getting close to the lines. If so 1.10612" is the minimum, if not. then the spec listed before will do fine.
Old 06-13-2009, 06:34 PM
wrd1972's Avatar
inch to inch and a half it is.
Old 06-13-2009, 07:00 PM
Counted Out's Avatar
You read that somewhere and remembered?
I wish I had that kind of memory.
Old 06-13-2009, 07:18 PM
integraxtc's Avatar
lol.erz
Old 06-13-2009, 07:46 PM
Smokinlt1's Avatar
Header wrapped the lines on mine.
Old 06-13-2009, 09:25 PM
strokin93z's Avatar
Yeah, its great! lol, i did make those numbers up. I was only feeding his engineer mentality on the situation. But to the OP 1 to 1 1/2 seems safe.
Old 06-13-2009, 09:30 PM
wrd1972's Avatar
Well the lines are still less than 3/4" away from a pipe. No good.
I am going to re-route them a bit to totally clear the pipe but I will need to get a bender from Home Depot.
I wish there were an easy way to shorten the lines some but because of that small flange that the plastic clip latches onto, I dont see how you can. I can shorten them some by pulling some of the lines toward the rear of the car thereby shortening them in the front.
Old 06-15-2009, 06:32 PM
Z-RATED94's Avatar
I put reflective insulating tape on the lines, and header wrap on the y-pipe for my car. I only had 1/2" of clearance.
Quick Reply: What is the minimum safe distance that exhust pipes should be from steel fuel lines?
