Any LT1 running AI come in !!
What kind of exhaust set up do you have and do you have any vids or sound clips and would you have done anything different with your set up.
Thanks Michael
Thanks Michael
Hedman Hustler stepped LT's, into a 3.5" Flowmaster merge collector (dual 3" cutouts right b4 merge) then into a 3" SLP 2OTL catback.
If I were to go it again, I would've kept my 3" TD setup.
Hooker longtubes into an x-pipe with 17" twisters run out the back. Don't have any clips of this setup but it sounds similar than these, just a little quieter at WOT now.
12" moroso spiral flows no cats
http://www.youtube.com/watch?v=OfbTNEm9rvw
This was with 12" moroso spiral flows and maganflow metallic cats.
http://www.youtube.com/watch?v=Uo9iRZao9yU
damn you got some good # with just heads and cam
Stock manifolds (for now) gutted cat into hooker aero chamber with slash cut tips. I got the catback from flyinZ. Thanks again. It sounds great right now, quiet at low speeds but really comes alive around 3000 and screams at red line. flows great too. I think it will have a nice low rpm rumble and REALLY scream with some LTs.
what AI package are you running ?
im running pacesetter long tubes with a off road y and 3 inch to the goerlichs xcellerator muffler and 2 1/2 tail pipes. Its not loud at idle and running down the road but if you put your foot into it it screams.
I'm currently running a 4" Mufflex w/flowmaster...not much room with this setup, its tight and a pita to remove, install.
The dyno numbers in my sig were with 2.5" x pipe duals dumped at the axle
