What kind of glue did you use on your fuel pump bucket?
Old 06-16-2009, 03:38 PM
pyro719's Avatar
Default What kind of glue did you use on your fuel pump bucket?
I used all seal last time and it didnt hold up to well. I was thinking about using big hose clamps to hold it together. What do you guys use?
Old 06-16-2009, 03:43 PM
ss.slp.ls1's Avatar
I used a 2-part plastic epoxy.
Old 06-16-2009, 03:48 PM
BTC
BTC's Avatar
Location: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
This is somewhat off topic, but is it difficult to get the bucket apart?
Old 06-16-2009, 03:58 PM
pyro719's Avatar
2 part epoxy is gas resistant? The bucket comes apart real easy. I dont know why GM didnt bolt it together?
Old 06-16-2009, 04:01 PM
ss.slp.ls1's Avatar
Mine was pretty difficult to pull apart. I had to use a razor around the lid edge to cut any epoxy I could, then I had to pry it open with a flat head.
You could always add some screw to it.
Old 06-16-2009, 04:10 PM
Mr.Whitey's Avatar
There are several old threads about this that go into detail. Polyethylene is difficult to "glue". The glue that is provided with the Racetronix kit is basically superglue, or so I've been told by somebody that would certainly know. I used some stainless steel safety wire to hold the two parts together. Drill a few pair of small holes in the bucket and lid around the edges. Then loop the saftey wire through and secure it by twisting the wire and removing the excess.
Old 06-16-2009, 04:37 PM
RamAir95TA's Avatar
Ironic enough, I did the same thing with my install. I just wasn't satisfied with the glue.
Old 06-16-2009, 04:42 PM
Mr.Whitey's Avatar
It's not ironic, you just copied mine.
Old 06-16-2009, 04:43 PM
MTBSully's Avatar
used the glue that came with the kit
RamAir95TA's Avatar
Fortunately I haven't copied your two-piece crank mod yet.
Old 06-16-2009, 04:49 PM
Mr.Whitey's Avatar
You didn't buy it from Golen, you're golden. (4 months and counting...still no phone call )
Old 06-17-2009, 09:13 AM
wrd1972's Avatar
What is the purpose of doing this mod?
Old 06-17-2009, 09:19 AM
myltwon's Avatar
2 part epoxy and a ziptie
Old 06-17-2009, 09:22 AM
lt1phantom791's Avatar
I used elmers glue and scotch tape
Old 06-17-2009, 09:27 AM
BTC
BTC's Avatar
What is used to hold bucket held together from the factory? Some sort of adhesive?
Old 06-17-2009, 09:39 AM
Village Troll
SS RRR's Avatar
I used super glue.
Old 06-17-2009, 10:02 AM
BTC
BTC's Avatar
Man, my sentence structure is unrivaled.
Old 06-17-2009, 10:12 AM
rkinney's Avatar
I also used safety wire.
Quick Reply: What kind of glue did you use on your fuel pump bucket?
