Tips on Removing/cleaning EGR
I've concluded that my high NOx reading (which caused me to fail my e-test) is a result of a poorly functioning EGR, or Cat. The Cat is new, a Magnaflow Hi-Flow unit, which I've heard many people use, with no issues, so I'm leaning towards cleaning out the EGR, and replacing it if needed.
I checked the Haynes manual, and the EGR is at the back of the intake manifold. How do you guys get this thing out? Take off the intake? Or just get your hands back there, fish around, and hope for the best unbolting stuff blindly?
I like to use a ratcheting wrench. Just make sure the engine is cool and lean over the front of the car, pretty much laying on the engine. Not that hard IMO. Don't bother cleaning it. I did that and it didn't help much, so I just broke down and bought a new one.
13mm nuts and make sure the valve is working. When you get it off, push the diaphram in and place your finger over the vacuum port. The diaphram should stay pushed in until you pull your finger off the port. If it doesn't, the diaphram is leaking preventing the valve from opening properly during normal operation.
