Intial Startup issues
Background: 93 LT1 TA, new 355 build, new gm opti, alt, starter etc. Tune by Ion, all grounds and sensors hooked up except AIR/EGR (deleted in tune) and one on the passenger side of the radiator.
First problem: put the car in neutral after engine and trans install to put in drive shaft, and key gets stuck in lock cylinder, now the wheel wont lock and the shifter can move with out depressing the brake.
Second problem: Finish everything up (still have problem 1), take out the injector fuses and disconnect the ignition plug and turn over to build pressure, turns over good and builds oil pressure fine. Plug everything in and turn it over, has the same feel as priming it. I get no spark and doesn’t sound like my fuel pump is engaging. Fun times…
Third problem: Get out the ol ALDL cables and plug her in to check out the problem, few seconds later VATS comes on and locks me out…
Suggestions?
Suggestions?
