View Poll Results: which intake
Voters: 6. You may not vote on this poll
between intakes need opinions
well i need an lt4 intake an the edelbrock one is 500. my other options an victor e with an elbow and ls style tb. thatll be a good amount more but ill have some things to sell to make up the difference. so which one should i do?
The LT4 intake is internally no different from the late LT1 intakes,the early LT1 intakes have a more rectangular port that might actually be BIGGER than the LT4 port.
The difference in the LT4 is material above the port. Whether there is enough material on an as cast LT1 intake to port match will depend on the heads and head work you are running. In some cases guys have just welded more material above the LT1 ports to make room to port match to taller port heads. Sometimes this is cheaper and easier than finding an LT4 intake.
I did not read your whole build thread but in the first post you say AI 200CC heads, in which case an LT1 intake will be just fine. Did you decide on different heads? If so ask the guys doing the heads what intake you should use
