Which way to hang eagle rods in 383
Old 06-22-2009, 10:33 PM
1fast432's Avatar
Default Which way to hang eagle rods in 383
Does it matter which way you hang the rods,serial number to drivers side or passenger as long as chamfer is to radius side of crank. THANKS IN ADVANCE!!!
Old 06-23-2009, 08:48 AM
moehorsepower's Avatar
Flat side is Rod to Rod but then again make sure your piston is facing the proper direction, most if not all pistons require facing usually forward of the motor.......
Quick Reply: Which way to hang eagle rods in 383
