Removed Wiring to power windows, I'm Lost
Old 06-22-2009, 10:49 PM
BLWNLT1_T/A's Avatar
Default Removed Wiring to power windows, I'm Lost
I bought some doors with manual window. Upon installing them I started removing all the wiring even went as far as removing the dash. I got most of it but I do not know where these 3 wires go... Any ideas from people that have done this would be great. Don't mind the bare wires it is a ground
Old 06-23-2009, 06:12 AM
InsaneAuto86's Avatar
They run to the driver side along that top portion of the dash... It looks like you are trying to just yank them all out. I'd advise against that. Do it the right way and remove the HVAC ducting.
Old 06-23-2009, 08:29 AM
I was going to yank them out but decided it was best not to... I appreciate your help....
Old 06-23-2009, 09:22 AM
I8ASaleen's Avatar
Since they are for the power windows (I'm assuming) then they should be headed to the BCM.
Old 06-25-2009, 11:19 AM
You see in picture were the wires go behind the duct. Well there is a little black box behind there where they all connect to. Should I remove it?
Quick Reply: Removed Wiring to power windows, I'm Lost
