timing chain problem
A friend of mine made a puller for the wp drive, he took a piece of pipe welded a plate on one end and then cut into the plate enough so that the inner diameter of the wp drive would slide into it and not the outer diameter. Then we just took a hammer to the back side and it came out eventually.
Sorry, if you saw it, but disregard my first response, I mis-read your question. I thought you were referring to the crank gear.
I can check later today to be sure, but from memory when I removed mine, it was bolted to the block with the bolts accessed with the intake off. Mine's a 96 LT1.
Jake
West Point ROCKS!
Jake
West Point ROCKS!
