ls1 breaks
Old 06-25-2009, 01:28 AM
mullet cruizer's Avatar
Default ls1 breaks
will stock ls1 brAkes fit on an lt1 and is there any modding that needs to be done to make this work?
Old 06-25-2009, 01:31 AM
Elliott's94Z's Avatar
Brakes
Old 06-25-2009, 01:34 AM
AxisOfOil's Avatar
if you do a search using the correct spelling... you'll find everything you need to know about that conversion.
Old 06-25-2009, 01:38 AM
the_merv's Avatar
It's an easy swap..alot of us have done it.
Old 06-25-2009, 01:53 AM
i feel like an ******* lol sorry guys, my car is in the shop right now, and i just had an offer to get the ls1 breaks for free so i wasnt sure if it was an easy swap or not
Old 06-25-2009, 06:03 AM
wrd1972's Avatar
Old 06-25-2009, 07:14 AM
nolimit5685's Avatar
save yourself the hassle and i'll drive to columbus to pick up the ls1 fronts off of you...
Old 06-25-2009, 09:18 AM
z_speedfreak's Avatar
why would you want anything from an LS1 thats broken
Old 06-25-2009, 09:53 AM
Z28Camaro30Ann's Avatar
BREAKS hahahahaha spell check is nice too lmao!
BRAKES
Old 06-25-2009, 10:43 AM
lol ok ok spell check brAkes, i kno i kno i fucked up. but is the swap worth the hassel?
Old 06-25-2009, 11:07 AM
the_merv's Avatar
Yea they are alot better..there really isn't much of a hassle to it too.
Old 06-25-2009, 11:23 AM
anyone know of a write up??..since he brought it up..and i'm boutta do it myself...
Old 06-25-2009, 11:37 AM
do i need anything else from the ls1 or just the brake setup?
Old 06-25-2009, 12:12 PM
the_merv's Avatar
Spindles, Hubs, Rotors, Calipers and Pads. Just un-bolt and bolt the new ones in, the Lines bolt in aswell.
Old 06-25-2009, 12:32 PM
I am considering swapping out my stock LT1 Rear end for a Stock LS1 Rear end. Make any difference???
Old 06-25-2009, 12:51 PM
trippinholyman's Avatar
both are ten bolts, rear brakes are like an inch bigger but not that much bigger. besides front brakes do 75% of the work i wouldnt worry about it and save up for a 12 bolt
Old 06-25-2009, 12:54 PM
Badazz 97 TA's Avatar
you will just need to switch the backing plates on the rear. since ls1 rear brakes are mounted in front as opposed to the lt1 rear brakes that are mounted on the back side. unless your getting the ls1 calipers/ rotors also then dont worry about it
Old 06-25-2009, 12:56 PM
yeah...the rear was free...labor is super cheap...thought about doing it as a temp thing till I get a shot at a better rear. I want to powdercoat the calipers too, my fronts are red and backs are stock...wanna make the backs red too
Old 06-25-2009, 12:57 PM
I am getting the complete rear end....the only thing missing is the wheels...
Old 06-25-2009, 12:59 PM
the_merv's Avatar
I prefer the LT1 Rear Brakes for the 15" Draglites.
Quick Reply: ls1 breaks
