93 383 into a 95
The block is the same but you will need to swap the timing cover, cam, and opti if you want to keep the 95+ vented setup.
Yea your 95 Tranny will work with the Engine.. I don't think your question was understood in the right way. As long as you use your 1995 Wiring and PCM you will be fine.
All you will have to do is swap the Timing Cover and Opti setup to a 1995 setup like mentioned above.
You will notice the 1993 has a different intake.
Nope. I am actually doing the same thing but backwards - a 95 block into my 93. I swapped the timing cover to a 95 one that has the proper opti hole but no crank sensor, will be using a vented opti and opti harness, and a 95+ cam. Keeping the 93 computer and harness for now. Tranny is not an issue since the 93s is not computer controlled, so like mentioned as long as you use your 95 harness you will be fine.
