the sensor on the oil pan is leaking
So, fresh motor and I see oil droppings. Good thing its nothing major, its just the screw in sensor in the driver side of the oil pan. I'm sure its not leaking were it seals but almost like its leaking from the plug. How do I go about fixing this leak?
Well put a new one on for 25 bucks and now it doesn't leak but my low oil light come on! Can you believe that! Maybe if I clean the connector up a lil more it'll make good connection and go off.
Under $30 from the dealership? Are you kidding me? Wow, when I called about 4 months ago they tried telling me $68 for this part. Unless they had parts mixxed up,, which is not out of question
