opinions on these rockers???
Old 06-30-2009, 05:04 PM
slownova73's Avatar
Question opinions on these rockers???
i just bought these scorpion rollers, 1.7 ration 3/8 stud
wat u think about them??
http://scorpionperformance.com/newsi...category_id=73
Old 06-30-2009, 05:34 PM
ss.slp.ls1's Avatar
I've heard people use them without issues. Are you using the stock cam?
You will need better springs, hardened pushrods, and I always recommend using ARP rocker arm studs.
Old 06-30-2009, 05:35 PM
96capricemgr's Avatar
scorpion is good stuff, some of the local dirt track guys swear by them.
Old 06-30-2009, 05:58 PM
slownova73's Avatar
i have in my possession the comp XFI 292 cam, beehive springs,and the heads are already ARP'd , my pushrods are 7.200, idk if theyre hardned or not, but should i get 7.300's to be on the safe side with that cam??, nothing has called for longer pushrods but idk
Old 06-30-2009, 05:59 PM
RamAir95TA's Avatar
Being on the safe side is measuring what pushrods you need, not guessing.
Old 06-30-2009, 06:09 PM
ss.slp.ls1's Avatar
XFI 292
242/248 .584/.579 113
I would only put that cam in a 383+ cube motor.
With 1.7 rr's the lift would be .661/656...you'd need a crazy spring kit to handle that kind of lift...not to mention the best heads/intake combo you can get to flow efficiently at that amount of lift.
You should take a step back and analyze what your goals are and buy parts accordingly that work together, don't just throw a bunch of parts together and hope it turns out well.
ThreeHonks's Avatar
where can you get a measuring tool from?
Old 06-30-2009, 06:18 PM
ss.slp.ls1's Avatar
You would need an adjustable pushrod and either a solid lifter or a test spring. You should be able to get all of the above from Comp.
You need to use the "sharpie method" to observe the wipe pattern accross the valve stem. Search for determining push rod length and you should find all you need.
Old 06-30-2009, 06:23 PM
goldmecham's Avatar
deff going to need some killer springs for that set up those rockers are heavy.
Old 06-30-2009, 07:14 PM
wrd1972's Avatar
XFI 292
And folks thought I was nuts when I ran .60x lift on my last cam. My Patriot etremes are good to .650 before bind. Not sure what can go to .66x" lift. Even if there are springs than ca go there, that valvetrain is gonna take a beating assuming they can even resist floating with the LT1 11/32" valves.
I would not even think about it.
Old 06-30-2009, 07:44 PM
slownova73's Avatar
its a forged 383 ci motor, i got a single plane intake for it, stainless valves,guideplates, beehives,all the good head hardware, just no portwork "yet" and about the pushrods, i have a checker i just dont know if i should get "longer" ones or not??
im not playing around with this engine! sum mouthy people need to be taught a lesson around here, plus itll be fun to drive!
Old 06-30-2009, 07:52 PM
ss.slp.ls1's Avatar
Definitely invest a lot of money on your heads. They will be the key to making hp.
With a nice set of 1.6 rr's the lift of that cam would be .628/.618. You might even think about a nice set of 1.52 ratio Comp Pro Mags. But I'd ask whoever is porting your heads about your valvetrain requireemnts.
You need an adj push rod AND either a solid lifter or a test spring to measure for proper push rod length. You need to use the "sharpie method" to observe the wipe pattern on the valve stems. Only then will you know if you need longer or shorter pushrods, not before.
Old 06-30-2009, 07:54 PM
You live an hour and a half from the best LT1 topend shop there is, why not take advantage of that.
The XFI lobes are HARD to control you will only make them harder to control by going 1.7s.
You are pretty much guaranteed to need longer valves to get enough spring in there to control that hell maybe even just to get retainer to seal clearance.
The single plane IF choosen properly might bring the rpm needs of that cam down. For now though stock heads are going to choke it LOW in the rpm range.
Old 06-30-2009, 07:58 PM
slownova73's Avatar
sorry i forgot to mention i have TRICK FLOW 195CC HEADS, and what shop are you talking about??
Old 06-30-2009, 08:00 PM
slownova73's Avatar
'currently installed on the car are comp pro magnum 1.52 sa rr's, i got these scorpions at a price i couldnt refuse!
Old 06-30-2009, 08:01 PM
ss.slp.ls1's Avatar
Advanced Induction
6841 Belt Road
Concord, NC 28027
Old 06-30-2009, 08:02 PM
ss.slp.ls1's Avatar
Then sell them and make a profit. Running that much lift is insane.
Old 06-30-2009, 08:04 PM
slownova73's Avatar
Advanced Induction
6841 Belt Road
Concord, NC 28027
ahh ok, ive seen the website but had no idea they where that close, thanks for that info man
Old 06-30-2009, 08:05 PM
slownova73's Avatar
thats the idea, but ill prolly end up running the pro mags, and maybe just slap on those scorpions and see what happens lol
Old 06-30-2009, 08:20 PM
95z28camaro's Avatar
The lift at .584/.579 is with 1.6rockers. So it would only be .620/.615 with 1.7rockers. With his 1.52rockers it will be .554/.550.
Quick Reply: opinions on these rockers???
