Crap my LT1 overheated!
Well for a while my temp gauge was reading about 210 which was a little bit over the 180 thermostat.. then today it went to the deadly redline temperature and yup...water shooting all over the place. The thing is though my service engine light was blinking(therefore misfiring) so I'm assuming that it has to be the water pump.. is there a way to tell if its the water pump thats causing the problem?? I'm pretty sure it is because it was leaking throughout the pump
man i hope the splines on the water pump are ok. i had a problem like that and found that the splines on the shaft of the pump and the splines coming out the timing cover were worn out. i didnt have time to take everything apart so i installed an electric water pump instead. have you checked you basics like the fans and thermostat? it sure sound like the problem i had.
I would assume that the heads are fine(I sure hope so! lol) but the opti I'm probably going to have to say no!! lol.. if it did I'll probably replace it while I'm at it also
