Pulled the Engine out..
I see that every now and then there is a thread on pulling it out the top or dropping it out the bottom.. I yanked it out the top and it came out pretty easily. It took a little but longer, but it wasn't that bad.
I took off the Exhaust, pulled the Radiator out, disconnected the drivetrain, took the front-end completely off, and then pulled it with a Cherry Picker.
This is the only pic I got..the camera died.
Overall it wasn't that bad..it came out complete with the T56 pretty easily.
Next time you can pull out EVERYTHING out the bottom. You don't have to remove a thing. The complete engine, Headers, trans, wire harness, and PCM will drop out like a charm. Trust me. I've done it both ways. I will never pull the engine out the top again. I even have the happy hooker tool (it does work) and I still won't go out the top.
You don't necessarily need a lift. You can use a pair (or just one if you have to) of floor jacks and a pair of 7-ton jack stands. I set the rear tires on ramps. Have my buddy and I go up on the body on each side in equal incriments. Once we max out the jacks we set the body on the huge jack stands. Then a 4x4 block on top of the jacks will allow the car to be jacked up high enough to sit on the stands maxed out. Now the car will be high enough to roll the engine and trans out on a dolly.
i pulled it out the top in less than 6hrs before its very easy but if your doing more things you might as well drop the cradle with everything, i was pissed after pulling the engine anyway cuz after the engine was pulled the customer says o yea btw pull the trans and frame anyway i have a bmr frame and new trans.....
Every time I see this topic I have to read it . I've done it both ways and to make the story short here's my opnion :
First off, If you don't have a lift and a way to lift the car high enough, pulling it from the top is your ONLY option weather you want it or not.
If you DO have a lift or a way to lift the car high enough, then you BETTER pull it out of the bottom because it WILL save you a LOT of time and work compared to the things you need to do to pull it out of the top, picture above proves it .
However, there's a CATCH pulling it out the bottom, it's called POWER STERRING SYSTEM. Thant thing (To me at least) is a ******* bitch to bleed (You also need to bleed the brake system), these two things you SAVE by pulling it out of the top.
So, in few words, if you don't have a problem bleeding the power steering system and you have a lift, then don't even think about the top.
If you never bled a power steering system on LT1s, do yourself a favor, yes work extra 5 hours just to pull it out the top.
I will NEVER do it from the bottom again JUST because of the power steering and prefer working many extra hours like an idiot taking many parts off that I wouldn't have to take off doing it from the bottom ,just to save that steering hassle.
Good luck.
Good luck.
I've seen it done that way..I guess what it comes down to is how much work you want to put into it. A benefit I have at the moment is that I don't have to bleed my Brakes.
I'd be pissed. It took about 3 and a half hours total, I did the Exhaust, Radiator and things like that on my own, a couple of friends came over to help with pulling the Engine. Plus I have air tools so that helps.
The other critical thing you mentioned is BLEEDING , it isn't as hard bleeding the brakes as the ******* POWER STEERING as I mentioned before, so doing it from the top will save you both these two things, but will add extra hours compared to pulling it from the bottom.
Adam
Who's having to bleed the power steering system?
If you disconnect the steering knuckle and unbolt your power steering resevoir, you shouldn't be lossing any fluid, hence no need to bleed the power steering. And as far as the brakes go, get your self a mighty vac and bleeding takes minutes...
Then you will be sure to take it out of the bottom EVERYTIME from then on.
Did mine out the bottom (by myself) with only a floor jack. No lift, no cherry picker needed. I've done plenty of out the top pulls on other cars in my life. This seemed plenty easy to me. No problems with the power steering and none with the brakes. I don't know what all the hubub is about that.
I have to bore it and get new Pistons..I have alot of Piston Rock and the Rings never seated.
As far as the Power Steering goes..just un-bolt it from the Engine and leave it with the Car. They both are easy..the LT1 one is actually easier..the LS one you will ned a Pully-Puller.
I also tore down my T56 today..that's really not that bad to do.
Not arguing , just trying to get tips from you because if I know the "trick" of keeping the power steering connected at ALL TIME even when there's a need to replace the short block (On which the accessory bracket bolt onto) then I'll do everytime from the bottom...
Adam
Thanks
