single plane ?
single plane ?
hey guys first i cant find a super victor anywhere that will ship in time so if you have one or know a place let me know. my question is y is the ford tps needed when using an elbow?
It really depends on the elbow - there are low clearance ones with tight radius low volume turns, and then full size gradual radius turn elbows that are a lot less restrictive. Then there are 860 plenum type "elbows" which are really boxes that sit on top of the carb mount allowing you to use either an LTX or LSX style TB depending on the model you get.
