Will a MSD cap and rotor fit?
same thing I have. Are you a 93-94, or are you a 95-97? The reason I ask is to see whether or not you are already vented.
If you are a 93-94 you are not vented stock. The MSD cap/rotor kit will make you vented in a way so you need to make sure you have 2 hoses about 2 feet long...one to go to the intake manifold, and one to go to your intake elbow. You may or may not need to modify the elbow...
If you are a 95-97 you are already vented and can use the stock hoses...make sure they are connected right though.
If you do not use the hoses, and run through a puddle wrong....water will get in and destroy your cap/rotor/ or even distributor....bad juju
