still on stock injectors
soo... i skimpped out on injectors. I'm in the process of getting a few things straightened out, outside of the car life. I've only got 600miles on the new build. Am I going to be hurting it due to the tiny injectors>? If so I'll just stop driving it, and just ride my gsxr and wait till i can get the bigger injectors/racetronix fuel pump kit/and tune obviously.
If you're on stock injectors, the only way to tell if they are too small is to measure your duty cycle via access to a scanner. IMO, you are pushing that combo with 24#. I'd suggest (t the very least)stepping up to 30+#. I went with Lucas/Delphi 42# injectors for my combo.
Internet Mechanic
It's been noted by a few professionals that at least on TTS Datamaster that the DC % is not the most consistant but until you know what power this thing makes and the A/F measure by a wide band, you just dont know.
To be honest, you can drive it if kept UNDER WOT and kept in the lower RPMs. Since most tuners not only take care of WOT tuning, they do part throttle and with that will do a "lean tune" for crusing (2,800 and below rpm) and A/F can be upwards of 14.5 to 1, BUT when you got WOT it drops to the command 12.8 or so (n/a).
Start checking plugs, drive a good distance, do not let it idle, pull into a parking lot and shut off and check. Reading plugs is always considered a good thing to do.
FYI, you should be getting bigger injectors. #30 Ford at minimum. I have used Racetronix as well with great success as they are that Delphi style injector vs the Bosch style like stock or Ford.
To me, seems like throwing darts at a board. Many say the formula method shouldn't be relied on.
If too much injector is installed, the PCM, wirh feed-back from the 02 sensor(s) can adjust, up to a point. However, at WOT the engine may well be too rich since in PE mode, 02 feed-back is ignored.
What I'd do is call my PCM tuner and follow the advice given.
Jake
West Point ROCKS!
Jake
West Point ROCKS!
Internet Mechanic
I upped my injector but in the end, i ended up tuning them down quite a bit. It was rich enough with the correction in the PCM.
he should be making 400-380rwhp but at a large drivetrain loss. So if you figure out your flywheel hp you can pick the exact injector for your application. Otherwise you are guessing, but when I threw the sizes out there is was to make sure your going to get a big enough injector for the amount of hp.
Sure you can run 30lbers on a 383 but if the topend was not a mild setup you were probably very high on the duty cycle. I would prefer to run mine closer to 70-75%.
Call racetronix.
Call racetronix.
Ok, so when I put the larger injectors in along with bigger tb and the racetronix fuel pump kit should I get the mail order tune so I can drive it to where I'm getting it dynotuned? Or just drive it there the day of the dynotune? I read somewhere, that "ring wash" could happen because of pcm not being tuned for the bigger injectors? Just retuning it with the mail order tune then paying again for the dynotune?
if it were me, id install the pump before, as it wont affect the tune at all, and install the injectors at the shop your taking it to(takes like 10 minutes, just get there early and swap em) i know a guy who ran his lt1 15 minutes before he tuned for the injector size, soaked his oil, then once tuned didnt change the oil for 3k. spun a number of bearings....
cool. sold my rims... started to chrome peel so whatever... stocks look good still, just not as flashy. After got the money went ahead and picked u some 36lb boschIII flow matched injectors from fic, one of our sponsors. Just a question when I put em on... do i just unbolt the fuel rails, and slap em in? or do i have to unhook the fuel lines first then do that?
