Which one should i go with ? HELP
I have a auto 96 z but was going to do a 6 speed swap and now im thinking of doing a FLT level 3 trans because it will bolt right up. I have almost every thing to do the swap but its going to cost me another 600 to have the swap done. Someone on another board has a flt level 3 tranny and wants to trade for a 6 speed what should i do ? HELP The car is pretty much a dd
Internet Mechanic
Depends if you race or not.
Racing a 6 speed is a pain in the ***, feel free to see this link. For me.
https://ls1tech.com/forums/eastern-m...ay-new-pb.html
the 4LJunkiE is no better but for racing it really helps.
The 6 speed is fun and when I didn't have one, I wanted it but then after issues with the clutch or hydraulics, going back to a good Auto (4L80e or TH400) really seems more appealing. Go with what you feel comfortiable with.
A Auto upgrade will be "easier" then a 6 speed swap.
Thinking its a relatively tame car, the FLT trans will work fine. It wasnt until I put a stall behind my old 383LT motor that my 60e took a dump. Ive got a 3 speed Th350 now and is alot of fun to drive!
If you like switching gears, put a manual valve body in a 3 or 4 speed trans. Its just me but I couldnt stand a standard in my car.
at some time down the road ill switch to a th350 or 400 but id like to see how fast i can take the 6 speed. problem is it'll keep me from bein competitive in any gamblers races
edit: when you doin the swap ill be comin down in august to NC for school id be willing to let you check the 6 speed set up out.
where are you going to school at ? That would be awesome all i need to get is a crossmember and clutch and flywheel but i have no job right now so im stuck lol
